Coolant in Intake Mani
XiKeiyaZI
6,994
88
Dec 28, 2008
Goldsboro, North Carolina
So I got my new Auto 2.3 in today, which we have a side story for about the delivery drivers 'test' driving the vehicles.....but that's for another thread.
I knew that this car was running rich, but I didn't know quite how bad. It is a 6 bolt swap and is wired up using the stock 2G wiring harness. Everything is wired correctly, but upon starting I could hear an obvious leak. Also, the exhaust smelled like coolant which lead me to believe that the head gasket was farked, even though it was properly milled, checked, and the head leveled. (IE I have the paperwork and recently got to see the block first hand... wow is all I can say.) Spraying it down with starting fluid, I found that there was a massive vacuum leak at the intake mani. We pulled the rail and the mani...and what I found explained where the coolant was going.
There was traces of coolant in the throttle body. The Pre-Heat coolant lines are plugged into it (they soon will be blocked and the FIAV blocked manually per Liquids' method. Upon removing the intake manifold, we found that there was about a good solid inch of coolant standing in it. Problem found - Throttle Body.
So, I am sure that the engine is still fine, having not damaged anything due to the liquid in it as the compression is 185 across the board..the lowest variation being 183. There were no bubbles in the coolant, no leaks in the engine. Everything else is pristine. I just want to follow up on this. By blocking off the FIAV per Liquids' (Scott's) method, and capping the coolant lines to the TB, this should eliminate any issue with coolant getting into the manifold, correct? Is there a way for a blown turbo to do this? I know that's a stretch, but that's the only way I can see coolant getting into the intake manifold.
Thanks for any input.
Actually, I lied. i just found the issue.
..........................................I can't stop laughing.
I decided to remove the emissions - The windshield wiper feed hose was plugged into the vacuum system. That's why the damned liquid was a bluish color.
That is awesome.
Joel
Pretty god damn much. I'm not gonna let him live it down. He and his dad are real cool, taking care of the issues with the shipping company. I just know, I can see his dad, a V8 guy working on it and going "What the hell is this....hm...." -plugs up- . Lmfao.
Testing tomorrow once I can get new gaskets to ensure all is well now.
I just realized how easy someone could do that since I just pulled the motor and hood, they'd look around holding the washer fluid line and just stick it where it fits, haha, this is one of the those rofl moments hehe.
Hahah. I know it was an honest mistake and I don't believe anything was damaged. Now I just pray that retorquing the head to 95 resolved any issies with the hg possibly being bad knowing its a metal hg. Exhaust no longer smelled of coolant. Just pure fuel.
that is legit how it happened.
he's the one who said it was the blower motor vacuum ROFL
i even had a good friend that works at chrysler get me the service manual, so i could do the vacuum lines. That was the only one not accounted for.ROFL
Well with all the problems we come across and see, this was the best one I have seen. Because no DSM's were hurt in the making of this funny moment. :thumb: Got a hella good laugh out of this. ROFL Thanks for the candied post. :D
