2G Coolant feed and return.
fabian95tsi
66
Nov 9, 2007
dodge city, Kansas
Ok guys so my new motor came with a water pipe that has the original coolant lines cut and welded up because the owner before me did not water cool the turbo and had a foward facing ofh. Now my hta fp green that's going onto my new motor needs to be water cooled.. can I use the circled lines to water cool my turbo?
It looks like he cut the return line off the water pipe. I can see where he welded it right where it meets the t-stat housing. That is where the return line is supposed to be. The fitting off the block is the coolant feed to the turbo. Refer to the picture I attached. Sorry it's been a while since I've worked on a 7 bolt.
