Constant putting
TURB0
89
Aug 20, 2004
Frederick/Salisbury, Maryland
I was out driving yesterday when all of a sudden my car began to putt rapid fire. It made the sound exactly like fouled plugs do, that boxer engine-esk grumble with slow acceleration. I thought it was no big deal because I am running on the rich side at the moment and figured I just fouled the set of plugs. However I pulled them out after arriving home and they looked fine. Just in case I went ahead and tossed in a brand new set. My Accel 8mm wires are also only a month old, if that. However, this did not stop the problem. It will put at any and all RPM's, even at idle. If I rev it even a little, it will create a big gun-like backfire. What else could be causing this? Coil pack maybe? Thanks.
Coil pack, transistor possibly, injector clogged/harness loose more likely given the scenario leadign up to your problems. If this does not cure the problem, pull the plugs/wires and verify if each fires (spark) when turnign the car over with the MPI fuse removed (prevents the injectors from firing) :dsm:
Ok, all my injector connections are tight, and the plugs are sparking. Is there a good way to test for a clogged injector? I guess I'll also just order a coilpack and see if that helps the problem.
  • For sale 2g NOS Sebring/Avenger floor mats
    These are slightly different shape than 2G mats but very close. NOS and still in plastic wrap. I...
    • MindBlowin03
  • Wanted 2g Anyone parting out a 2G?
    Need a few bolts that I'm missing for the rebuild, subframe and crossmember specific. Anyone...
    • Mahreeoh17
  • For sale 4G63 Mitsubishi # 284K00708 tach filter
    Mitsubishi OEM tach filter. With weather pack connector. Message 702-741-6987.
  • For sale 1g NEW ETS Street Intercooler for 1G DSM ( 4” Core )
    NEW ETS Street Intercooler for 1G DSM ( 4” Core ) $475 + shipping & paypal fees* these are...
  • For sale 2g 2g power window motors. OEM
    2g RH and LH power window motors OEM, $30 each. Sold the drivers and pass set of door switches...
