constant clutch failure
eclips3_xs
79
Jul 23, 2008
Burbank, Illinois
I have the biggest and angriest problem of them all. I keep loosing clutch pedal pressure. I bleed it thousand times and i get to the point where there is no more air bubbles i tighten the bleeder and after a while i get it over again. So i changed the slave valve the clutch master cylinder and bought new clutch line the straight through and still i get the f***ing bubbles im loosing my mind here i dont know what to do where the bubbles come from. I have every screw or possible connection sealed and i get the suckers what could be the problem pleas i need this. Little thing couses so much pain u guys have no idea ok that's it.
how long is the bolt on the peddle sticking threw the square u bolt that hold the pedal to the rod
Also you said you had changed the lines did you change all 3 or just one, and one more thing did you check the line from the clutch fluid reservoir to the master cylinder i would try changing that line and maybe even the reservoir.
