compressing fiav spring question
El Cuervo
576
27
Nov 7, 2004
Omaha, Nebraska
Those that have done the free fiav delete mod. How many times did you have to turn the black knob with the 4 dimples and cross like shape? I was only able to turn it almost 1 full turn. What do you guys think?
Pretty sure I turned it like 3 or 4 times. Careful with it. The plastic can get brittle and stuck. I had the knob seized on my 98 throttle body. Pain in the ass that one. Spray some PBB in there.
Mine turned in quite a few times. I'm experimenting with a new approach by removing the spring.
It may have just been on my TB from constant removal of the plug but it did encounter a boost leak through the freeze plug.
So I recommend putting an RTV seal on it when you put the plug back in.
So I guess I should try turning more? It seems like I can't turn it anymore. It shows about 1 to almost 2 threads on the inside walls of the cylinder.
By the way, would you guys happen to remember how many of these threads are exposed? A you turn the knob, the threads start to show. So I'd like to use this as a reference.
Maybe the number of threads showing is a much more accurate way of knowing how deep the knob needs to be, instead of how many turns it should have before bottoming.
I'll try some pbblaster.
