CatchMe
- 127
- 0
- Jul 22, 2003
Kingston,
Massachusetts
How many of you blocked off the Fast Idle Air Valve?
I'm having some idle issues in which I've done everything but block this off. What happens with my idle is that when I free rev it up to 2300rpm+ It will stall out upon decel. Cant figure it out.
*I have no major boost leaks
*ISC is functioning properly
*BISS is set properly (dsmlink shows value of around 30@900rpm
*Im flowing .28 g/rev at idle which is correct airflow
*PLX wideband says 14.xx for a/f at idle so its not overly rich
*I am recurculating my BOV.
*This is unrelated to this problem but for reference, but I have a ACT lightweight flywheel, no balance shafts, no egrs. Had these with the EVO16G and never had a stall issue though.
This problem occured when I changed my turbo from a EVO 16g to a SBR gt12 along with a 3.5in intake Dejon Tool intake pipe. I also changed my spark plugs to NGK BPR7ES gapped to .028.
My last resort on fixing this problem is checking to see if some of my injector seals are leaking and blocking off my FIAV because I've seen some people have had success with that. Let me know what you guys think. Much thanks to those who take the time to help me.
EDIT: Also, if anyone has a good link on how to block off the FIAV it would be a great help - I have one that someone fabricates a block off plate...But I also hear you can JB Weld or fill certain ports which is what I'd rather do than fab up a plate. Thanks again!
Help me out
. And another time the idle pos sensor connector came off. Also turning the BISS out enough and having the ISC compensate by closing with all accessories off helped me quite a bit cuz then it can only open for loads. It stalled once since then at night with highbeams, stereo, rear defrost, blinker, braking, neutral, and fans going; and it was prob cuz it hit a hard note.
