comp cams
1badturbo
114
Jun 8, 2003
tulsa, Oklahoma
I just bought a set of comp cams 101200's, has anyone used these or heard anything good about them.
nothing but great things to say about the comp line. I love the 200's. they are a great value and usually are readily available. You will love you mid-top end gains and not see a huge drop in low end torque. Your 50trim is going to love them.
I have the 101200s also and car pull all the way to 7500rpm with the JM SMIM, FP3065...etc. Very good cams.
I also agree with Martin. I have had them for 2 years and love them.
project_tsi said:
Same as what Martin said, I kinda wished they loped a little more. Other than that they are great.
If you want them to lope a little more, lean the fuel at idle and you can get the lope. Ive done it just for the intimidation factor.;)
Do you need aftermarket springs for them or will the stockers work.
I don't plan on reving past the stock limit till I can build the bottom end but, I also dont wan't to float a valve because the cams are to big.
    • dsmmario
    • Detail
    • dsmmario
