foxfan88
- 31
- 0
- Apr 27, 2009
Miami,
Oklahoma
Couldnt find any info on this.
But i recently bought a 91 TSi AWD talon. Its a complete car, but the engine had a knock.
I ripped the engine (6 bolt) out of the car and tore it down, and i found a FUBARed balance shaft bearing hanging out in the crank case. Seems a bearing for the lower BS slid out. Then the balance shaft proceded to hit the side of the block, there are obvious wear marks on the shaft and the inside of the block.
I didnt know if this was a common problem.
The car had an oiling issue which turned out to be a clogged oil filter, this was before i got the car, and the engine was cranked with no oil pressure and maybe ran... The rod bearings looked DECENT, werent the best. The main bearings were pretty worn out.
It looks like i'll be replacing the rings and bearings and getting a BSE kit.
Guess its better than i thought, I was thinking it was going to be a spun bearing, but turns out the balance shaft was making the noises. The crank is in good shape so i will need to measure and get my bearings and etc.
Is there any precaution i need to take since the BS was hitting the inside of the block. I doubt it hurt anything, but it never hurts to ask.
Thanks,
Brett
Thanks,
Brett
! Seriously, if the shaft bearing wore to the point that the block bearing seat was damaged, then even with the eliminator kit, you could lose oil pressure and that could be a problem!
