color code/color
tonypanda
300
Jan 18, 2011
murphysboro, Illinois
i need someone to help me out i looked on my car at the color code and its not readable so ill see if anyone can help me find out the color of my 95 esi its blue and my talon and avenger are the same color
After looking into it a bit in '95 Mitsubishi only sprayed one type of blue paint which was Kona Blue Pearl (B73). In '96 they also included Celtic Blue Pearl (B59) and Bright Blue Pearl (T73). So depending on when in '95 your car was manufactured you might have a different blue paint on your car since some of the late '95s could still have been sprayed with the knew '96 colors. Try to find the paint code on the placards from the manufacturer or at least make out a number if you can. If you want to be absolutely sure call the dealership and give them your VIN #, they'll be able to help you.
:dsm:
1998 Mitsubishi Eclipse Touch Up Paint Colors
As Corey stated above, you can call the dealer with your VIN and they will tell you. If you have CAPS or ASA, you should be able to plug your VIN into it and it will tell you the exterior code as well. If you'd like, you can PM me the last six digits of your VIN or your whole VIN and I'll look it up for you.
