coilover suspension noises
tsi4ya
157
Aug 3, 2004
Austin, Texas
okay there is this sound coming from the top passanger side suspenision and i cant be point it!!!! i know it makes a louder sound when i turn the wheel. . . .at frist i thought it was power steering fuild but that wasnt the case. . so now am soooo lost. could it be a bad spring???? anything helps . . and as always thanks.
Check your ball joints. The joint in the lower lateral control arm are notorious and are covered under recall. Then there is a joint in the upper control arm and the compression arm. The springs have also been known to creak when turning in the hats.
Yes, when i bought the car i found out about that recall and acording to Mist. they have been replaced. . . thanks for the tips. . .what should i look for when examing the that side? thanks again
Flash said:
Your profile says you don't have coilovers.
But the thing that comes to mind first are the bushings.
yeah i know i dont know what i was thinking. . . i thought if i had a bad spring why not just replace everything?
  • For sale 2g 99 2G parts
  • For sale 1991 Mitsubishi GTO
    1991 Mitsubishi GTO JDM Import
    • jesuschr
    • ist dwa
