Coil Problem? No Spark. Completely Lost
HiBoostGST
42
Oct 10, 2008
North Charleston, South Carolina
Here's the problem, I dropped my motor back in after going through it. Everythings back together but the car wont start. I have fuel pressure, power going to the Coil pack and the secondary resistance is correct, but still no spark. I have been trying to troubleshoot but cannot figure it out. From the wiring diagrams on the ignition circuit i think i have narrowed it down to either a problem with the MFI system or possibly the cam sensor. When i got the car, there was no CAS installed on it but yet it still ran. I dont know how this is possible bc i work at a GM dealership and i now our vehicles wont run without it.
From the harness i have 12V power coming from the correct pin on the connector to the coil pack but i dont get anything else when trying to start the car. If i have a test light hooked up, one of the other pins should intermittently illuminate the test light if it the signal is coming from the PCM/ECU.
Any help would be awesome, im completely lost at this point. THANKS!
EDIT: ok so after some research, I def. had the MFI relay confused with something else in the engine bay. However, still have the problem with the coil pack situation. Im still needing help.
No, that's part of the problem. I dont have a CAS. and i didnt when i first got the car, but yet it still ran. So i cant be sure that is the problem.
The relay shouldnt flash the light, it has a neg pulse on one side of the relay and that is from the ecu. Not sure on the rest of your problem though, just thought I would point that out. There should be one line in the relay that seems dead, 2 12v and one that flashes a neg pulse for a couple seconds when you first turn the key.
Good luck!!
420a- are you referring to the connector that goes to the coil or the MFI relay? I dont think the MFI is the prob but something else. thanks for your input though!
Are you 100% sure you dont have a Cam Angle sensor? All 2g's must have a cam angle sensor and crank angle sensor....And only certain 2g's wont use a crank angle sensor...(6 bolt swapped 2g's)
This is where your 2g cam angle sensor is...
Ya i do have a CAS. FOUND THE PROBLEM it definatly helps if you hook up your ignition control module. I completely forgot about it when i bolted up my JMF SMIM. Thanks for your help everyone!
Good shit!!
I was talking about the ASD/MFI relay, and testing it. Same procedure for each. 1 ground, 2 12v and 1 neg pulse from ECU when the key is first turned.
Glad to hear you fixed it!
  • For sale 2g NOS Sebring/Avenger floor mats
    These are slightly different shape than 2G mats but very close. NOS and still in plastic wrap. I...
    • MindBlowin03
  • Wanted 2g Anyone parting out a 2G?
    Need a few bolts that I'm missing for the rebuild, subframe and crossmember specific. Anyone...
    • Mahreeoh17
  • For sale 4G63 Mitsubishi # 284K00708 tach filter
    Mitsubishi OEM tach filter. With weather pack connector. Message 702-741-6987.
  • For sale 1g NEW ETS Street Intercooler for 1G DSM ( 4” Core )
    NEW ETS Street Intercooler for 1G DSM ( 4” Core ) $475 + shipping & paypal fees* these are...
  • For sale 2g 2g power window motors. OEM
    2g RH and LH power window motors OEM, $30 each. Sold the drivers and pass set of door switches...
