coil pack
420aVOS
67
Nov 9, 2004
poughkeepsie, New York
hey quick question, does the coil pack for a 420a need igniters or anything? because im putting in a standalone in and not sure if i need to get a 2 channel igniter to run or if it can run with 2 ground side switches in the ecu. thanks
I'm not 100% sure about that. Can't say I've ever heard anyone mentioning "ignitors" in advanced 2GNT discussions. I do know a couple people running two channel systems, but even so, that's more than likely going to end up a wasted spark scenario to work.
What standalone system?
EDIT:
NM. Looks like you're running the Haltech. (See how useful it can be to update your profile, no0bies?) I still can't give you a definitive answer either way. I know of people running something like a DIS-2 or DIS-4 off the two ignition drivers on the Megasquirt, but like I said, they end up with wasted spark. It's not really that bad, imo.
  • Wanted 2g 2g Hood latch support
    On the hunt for the support that holds the hood latch assembly.
    • jesse12345
  • For sale 4G63 Hallman ES Boost Controller
    Boost controller
    • jpturbotalon
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
