Coil Pack/Connector Plug Issue. Need Help!
BoostedinSoFla
1,950
19
Nov 1, 2006
South Florida, Florida
Ok, so this problem has been bothering me for quite sometime. My car wont start on the "first turn", it takes about 5 turns before it starts up and runs. When it does run, it seems as if it bogs a little and then starts to idle fine. I was stumped until I got a CEL few months back and when I pulled the codes this is what I got:
P0352 - Ignition Coil B Primary/Secondary Circuit Malfunction
P0351 - Ignition Coil A Primary/Secondary Circuit Malfunction
I now notice that if I push in the connector plug that plugs into the coilpack (it's loose) the car starts fine. I unplugged the connector from the coilpack and there were little broken pieces of plastic so it seems as if the connector plug is defective and wont mate properly to the pins.
Now my problem is this, I have a 95 so I have round pins and every local junkyard I go to has flat pins which I guess is for 97-99 N/T's. Can I just cut the connector plug wire from the engine harness and just replace the entire coilpack and connector plug for the flat-pin type? Pic attached below for reference.
Yes...
Just strip the wires, attach the appropriate ends (solder is best), insulate them well (heat shrink tubing or electrical tape), and you should be good to go.
Sorry I'm not home, otherwise I'd help.
Damn, you're still having that problem. I remember when it first happened I wanted to do the same thing. U Pull It should be a lot of fun this weekend btw.:D
Replaced the coil/connector to flat-pin type and I still had the same problem.:toobad:
I checked around the engine bay some more and turns out the CAS was unplugged from the HG job, been driving with it for 2 weeks now.LOL :toobad: Problem solved.
  • Wanted 2g 2g Hood latch support
    On the hunt for the support that holds the hood latch assembly.
    • jesse12345
  • For sale 4G63 Hallman ES Boost Controller
    Boost controller
    • jpturbotalon
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
