Code p1500
Alternator FR output bad (open circuit), or open wire/bad connection from there to ECU pin 41, or bad ECU. Voltage should drop on that alternator FR pin 4 (green wire) when turn headlights on. I can scan you the troubleshooting chart if you're willing to shoot it with a voltmeter and you pm me an email address that accepts attachments.
But FIRST just check that green wire on the 4 pin alternator connector for good connection (it may have just broke off).
