clutch , tranny or both??
prophecy7115
345
4
Apr 23, 2005
Miami, Florida
i realized that my clutch pedal feels softer and like if w/e held the pedal to the actual clutch got loose.. for example i would have the clutch down in first gear and i will semi-grip with the pedal all the way down!. the car would creep too 5 mhp in first gear with clutch all the way down, i am like WTF and before the incedent i would have to let the clutch about 2-3 inches before i would feel a pull now i barely let it go and i am already gripping in gear.. but the clutch holds strong once engaged no slipping on WOT.. and after 1st gear it wont go into any other like the clutch doesnt open all the way for the clutch to let the gear in ..i have to rev-match and throw th gear in! that suks
And not to mention my second gear that poor thing is gone!!it does not go in at all!! u hear nothing but a horrible grind!.. my synchro doesnt exist in my tranny any more. WHATS THE REPAIR COST? HELP!!!!!! .ok anybody with insight on what happend here with my clutch.. oh plus there is a horrible vibrating when releasing of the clutch (mind you the clutch has probly 1,200 miles on it). i would appreciate any opinions thank you very much!
IVAN :dsm:
You probably ruin your throwout bearing or destroyed your input shaft sleeve. Drop the tranny and see what happen.
    • Sdcryan1
