Clutch Problems i think
Church
123
Jun 12, 2002
New Jersey
I have a act 2600 with about 45000 miles on it driven hard. The clutch seems to be slipping but only when i shift hard. It does not do it at the top of gears or anything, its fine if i gas it all the way to redline except for when i go to shift then it feels like its slipping when i take my foot back off the clutch in the next gear. Rpms advance pretty normally and i dont smell clutch which is uncommon after slipping all the way through 2nd or 3rd. When the stock clutch went i would gas it and the rpms would shoot up, it's not doing this now. I was thinking maybe my clutch needs to be adjusted. It is grabbing pretty high right now but i hesitate adjusting right away cuz it can be a pain in the ass.
Some opinions would be great
Thanks
Also, peel back the boot on both the slave and master cylinder to check for fluid leakage. If so, either rebuild the cylinders or replace. Good luck.
