Clutch problem?
PurpSalad
195
Aug 24, 2010
Orlando, Florida
Okay so i saw a couple of threads that were SOMEWHAT close to this, but they werent my exact problem, plus i couldnt write anything in those threads for some reason. Okay so my problem is this. U cant bleed the clutch because a line is leaking. when i bought the car the dude showed me the leak and everything but after lookin at it for a long time i realized that this followin picture is what seems to be leaking...
looks like...a filter. im not sure. its on the left side of the car and i felt around in there and thats what seems to be leaking. unless its a line on top of that leaking onto it. the leak is minor,it was out sitting all night and dripped maybe a few drops, but its letting air in so i cant bleed it, therefore cant drive my car(AHHHH)haha
Anything will help, thank you.:sosad:
Unless the clutch hydraulic line was replaced from the master cylinder to the slave cylinder (at the transmission) AND rerouted on the driver side, that line in the link has nothing to do with your clutch.
I have no idea what the metallic line in the center is. The picture is not very clear. Making things simple, that filter is your oil filter for your engine. Nothing on that side of the engine (by the OFH) has anything to do with the clutch system if a rerouted line has not been done.
Nah, clutch line runs from center of firewall to a mounting bracket over by passenger side fender where it changes from a rubber line to a metal line and runs down to the slave cylinder on transmission. By the way the picture the wire hanging goes to power steering pump there is a small nipple on the front side of it, just clips right on there I believe it is some sort of speed sensor... not certain of that but none the less that is where it mounts.
    • Sdcryan1
