clutch line install no pressure
highlandgst
805
May 11, 2009
miller, Indiana
got me SS line installed and everything and I have no pressure in my clutch now though ive tried bleeding it by loosening the bleeder valve with the vaccum line in a cup of brake fluid but nothing even came out with the clutch depressed . the clutch fluid res stayed full as well . Any idea?
That's because that's not how you bleed the line. Have some one push clutch and hold it in. Crack open the bleeder with a 10 mm wrench to allow the air bubbles to escape. Keep your reservoir full. Repeat until pedal is firm. The first few times you may have to pull the pedal back up with your hands.
There are more in depth directions in your repair manual or check out this link. Also this link has lots of pictures!
Hope this helps!
thanks man i did it the one man way just now and got it working but hte hose from res to master is kinda loose so i had to tighten it with some zipties til i get a clamp that was my main problem i got it goin now thanks all :p
