Artago
- 2,094
- 31
- Nov 30, 2006
North Vancouver,
BC, Canada
Hi all, got a problem.
Just installed my ACT 2600 with XACT flywheel and ACT TOB (I know, but please save that for another thread).
Anyways with the slave cylinder removed the clutch fork is to the right (driver side) and I can't not move it at all with my hand.
With the salve cylinder out shouldn't I be able to move the clutch fork to the left (passenger side) until the TOB makes contact with the pressure plate?
Since I can not move it at all, does that mean that the TOB is currently pressing on the pressure plate? If so, then that will kill my thrust bearings quickly, corect?
What I want to know is if it should have some free play before the TOB contacts the pressure plate and since mine doesn't it means it's ALREADY contacting the pressure plate.
How do I get this free play back? Do in need to step the flywheel? Basically cut it down so create some room?
Thanks all,
Tom
Thanks all,
Tom
