Clocking External WG
dalatinromeo
889
26
Nov 18, 2004
Fair Lawn, New Jersey
So when installing my FP3150 I couldn't get the side nipple of the WG pointing forward towards the front of the car because the nipple kept hitting the exhaust manifold. So to get the install done I installed the wg on the turbo with the side nipple under the exhaust mani and towards the engine.
I thought the heat was going to burn the vac line but I wanted to finish the install. So a week after my install I'm driving I get on the car and the boost goes towards 18 psi and keeps climbing so I left off the gas because I had it set at 14 psi so I was wondering why did it go up. I check the lines and I see the vac line starting breaking apart.:notgood:
How did you guys get the nipple towards the front everthing I tried didnt work?? I was thinking maybe I can "clock" the top of the WG but I wasn't sure. I know the top part comes off so you can change the spring so I thought when taking it off. I can clock the top of the wg. IS this possible??? I just don't want to take off the wg to find out it can't be clock.
I can snap a photo later to explain better.
It's Tial 44 WG. If I rotate it forward the nipple hits the exhaust manifold. Sorry I really can't explain it I'll snap a picture later.
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
