EBC Routing with External WG
RT-AWD
395
Apr 28, 2007
Norristown, Pennsylvania
According to this diagram i need to have a line hooked up to a boost source. I have no nipple on my compressor housing or on my ic piping. Do i hook up a line using the nipple on my stock intake manifold? Also i dont have a nip on my intake pipe to route a line to where it tells you to hook up to the preturbo pipe (snorkel) where do i put that line?
bcsinstall [ECMTuning - wiki]
I just went from an internal wastegate to an external wastegate on my turbo.
You need to tap either the compressor cover or ic pipe to create a source. And the vent line can be routed into the intake tube if there's a nipple or left alone and it vents to atmosphere.
ok so I now have everything ready to be setup. how does the vacuum hose get routed? I have the Ingersol rand solenoid, I don't have a bung on my intake pipe so the port indicated for the snorkel will remain vented. I don't know which port my greddy rs BOV should be connected to? Also, should I just plug the two bungs on my intake manifold?
