AWD-Tony
- 6,787
- 3,748
- Sep 11, 2017
Cincinnati,
Ohio
So I’ve come to find out that JMFab recirculating O2 housing (for tial 44mm wg) is not a good fit for 68hta w 8cm housing. It actually touches the p/s pump and turbo has to removed to do anything on the timing side. This includes adjusting your p/s belt tension. Long story short, it’s not mentioned anywhere that this O2 housing is for 7cm housing.
Just curious what O2 housing/EWG setup you guys are running w 68hta V2. Pic would be great.
Thanks
Tony
Thanks
Tony
since buying another wastegate won't be that cheap, so. When I had a FP manifold I had a tial 44mm on O2 housing, never had that clearance issue with the P/S pump. But it was atmosphere dumped, not recirculated. and sure you're welcome hahaha
