Clearances for 6 bolt Build
The Chazz
88
Apr 15, 2008
Denver, Colorado
Hey there....picked up a lightly used 6 bolt forged bottom end.
Considering i've had 3 7 bolts crankwalk/spin bearings......i think it would be best to open it up and just check the clearances.
Anyone have a list for main bearing/rod bearing journal clearances along with piston to cylinder wall?
I'll have it up on the stand hopefully tonight/tomorrow....so i can show you guys whats up.
Thanks!
best bet is to pick up a haynes or chilton maual, they have all what you ask. I'm sure someone here with a 1g book will beable to spot you the info needed.
Connecting rod bearing oil clearanc=.0008-.0020
Main bearing oil clearance=.0008-.0020
Find out what pistons are in the block and then contact that manufacturer for their piston/clearance.
