clear liquid leak 92 talon tsi .
bakedgoods1312
Aug 22, 2012
jblm, Washington
I just purchased a 92 eagle talons Tsi. I drove it around a bit and was driving very nicely . However when I parked it at my house I noticed it was leaking a clear odorless liquid from the very front right of the car . I drove the car around the block again and it still operated normally. I'm not sure if this is break fluid or just condensation. After touching the liquid my fingers had a very faint sticky feeling to them .
I'd look to see if it has coolant of water in the cooling system. Also it is possible that it is water coming from the ac system if the car still has ac.
Could be power steering fluid. Most of the stuff Wal-Mart sells is clear and sticky, which is very common since people are cheap and the stop leak is clear. The power steering pump is a common place to leak.
Condensation is possible as well.
Sounds like water from when you ran the a/c. Leave the car parked for a little with the ac blasted and see if you find the same stuff.
I really appreciate the feedback unfortunately I was parked in the grass when this happened so I couldn't really exam the fluid but I will check these things out and get back to you all.
The only one I didn't see mentioned is clutch fluid. If the other possibilities are not it check your slave cylinder.
Keith
  • Wanted 4G63 Wanted
    Looking for a kiggly HLA
    • steelcurtaindsm
  • For sale 2g 1998 Eclipse GST Rust Free
    Rust free, not perfect, prob needs motor soon. 125 compression all 4
    • Zanaqqq
  • For sale 1g Int door plastics MB517837 and MB517834
    • ist dwa
  • Wanted 2g WTB CLEAN HVAC PARTS
    Good condition , clean please no rodent infestation
    • ames905
  • Wanted FIC Easytune
    Looking for a FIC Easytune box.
    • Stapl3
