2G choosing correct BOV pressure spring
2gEclips3
119
Aug 14, 2013
Lena, Europe
Im about to get myself a Tial QR BOV on extremepsi, but i dont know wich pressure spring to choose. Im quite uncertain, but i have read somewhere in on the forum, that with the stock T25, it does about 12 psi at idle, but i dont know if that have anything to do with wich pressure i use on the spring.
I have tried to look for answers in the forums here for a couple of days, but i havent found anything similiar or if its because i havent searched enough, so sorry if this is the millionth post on this subject.
atm i run a pretty stock gst.
i have also read that a 7LB spring would suffice to stock, and iv'e tried to find a converter online from LB - PSI, and found nothing. Only that 12psi is the same as 0,8 bar, wich is the same measurement for turbo boost.
wich spring should i use? there are 6 options, all from 2psi (superchargers only) to 12psi.
I personally would look for an adjustable valve, you would be better off ordering both the black and white springs just to be safe. You want to use the lightest spring possible that will hold under vac conditions. Oh and PSI is short for "pounds per square inch", no conversion is needed. Contrary to popular belief bov springs are rated according to the amount of VAC pulled, not boost.
I figuered that much, but then again i cant understand why they list the pressure springs in psi at extremepsi.com
Guess i will order two springs like you said even tough an adjustable spring would be easier, but i got plans for the car wich include a bigger turbo, then i can just buy a stronger spring. And it seems tial is one of the most trusted brands amongst dsm'ers
