Spring Pressure?
The spring pressure is the least amount of boost you will be able to run. For example, If you buy a 10psi spring, you will not be able to run lower boost than 10psi, but you can run higher than 10psi with a mbc. Buy whatever spring suits you best, I wouldn't go too high though.
DSMBen said:
so like 10? that a good number?
DSMBen said:
I'd have to say you got screwed on you education. Can you not take the time to spell correctly? I could hardley make out what you are trying to say.
:tease: Please do use proper grammar and capitalization when posing in the tech forums, thank you.
Spoolin98 said:
Wow Bruce, your reputation is by far the biggest I have seen. You must be a pretty popular guy.
Postwhore yes, popular guy no, you should see some of the hate mails I got after becoming a moderator. :D
