Checking cylinder head flatness?
A fire ring is when the sealing ring around the cylinder bores of the HG dig into the aluminum of the cylinder head, It also happens to a cast iron block.
A straight edge and feeler gauge will not show this, due to the width of the fire ring, the feeler gauge will bridge over it.
But you should be able to feel it with your finger in most cases.
