cylinder head
bstclum
56
Sep 18, 2005
spokane, Washington
Ok I'm putting a new head on the 1991 Tsi awd, and was wondering what the foot lbs. of tork is nedded to put it on the block? I'm also putting in new stock cams in I need the foot lbs. of tork for the cam caps? My Chiltons got lost and I can't afford to buy a new one since I just spend a crud load of money on the head and cams.:talon:
Your stock head bolts should be torqued to 80 ft/lb as per the manual, not to be confused with 95-99 torque to yield head bolts.
Follow the other link DSMcamaro posted for the cam bearing caps.
Yes, and don't forget that "tork" is spelt torque, as mentioned above. It'll probably get you more results. :thumb:
-Kevin-
