Check out my E85 WOT log
boostdawd
Supporting Member
1,430
320
Apr 6, 2010
phoenix, Arizona
1). No boost, vac, or exhaust leaks.
Boost tested to 25psi and holds for a few seconds. Greddy BOV is leaking just a bit from adjustment screw
2). Verify mechanical timing.
Yes
3). Verify base timing
5* BTDC
4). Ignition system
NGK bpr6es gpped to .025
5). Motor health
130 136 130 128
6). Basic throttle body adjustments.
yes
7). Compression ratio
stock
8). Wiring and sensors
all checked
9). No DTC/CEL codes
no
10). Electrical system
running strong
11). Base fuel pressure and injector values
43base fuel presure
12). Properly calibrated and configured wideband sensor
yes
13). Type of fuel
E85
14). ECMlink how-to videos
yes
I have been working on my tune for a while now. Mods are up to date in my profile. Looking for constructive feedback and any changes, improvements you guys might suggest. Going to get my car tuned on Saturday but im trying to learn as much as I can. Thanks guys
AFRest and actual afr are quite a bit off, at least it is going richer which is better than going too lean. Will need to change global fuel setting and rework your SD table, smooth it out while also getting afr to line up better with afrest. Not adjusting global fuel will give you rather inflated SD table numbers. The knock you are seeing that starts at 5200 rpm on to 6700 rpm may be from going to rich (down to 10.7 afr) on e85.
I have 1000cc injectors on 43 psi. I've read in ecmlink and threads here to calculate global fuel for e85 by
1000 * 0.670 = 670 then
450 / 670 - 1 = -32.835%. Ill make that adjustment. As far as speed density do u recommend increasing or decreasing the sd sliders? Total newb I know
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
