Charging Problems
brn2race96
32
Nov 27, 2004
chicago, Illinois
Hey!
car: 96 eclipse gst with a 6bolt motor
Summay: Need some help with this, I seem to have tried it all but nothing works. The problem is the alternator is not charging. The Origanal alternator tested bad after replacment the problem remains. Checked and rechecked the alternator and the battery. I have replaced the battery and the alternator with NEW parts.
Questions:
1. The connector that plugs into the alternator are there three positive and one ground?
2. The two wires together connected to the side of the alternator that run to the battery dont show any power. are those wires a return from the alternator to charge the battery or are those wires suppose to power up the alternator. Because it shows no power when the car is started...
Please gimme any trouble shooting suggestions.
This is what i have tried and checked.
Checked the battery and its terminals for corrotion. Checked the alternator. Checked the alternator fuse in the fuse box. Also keep in mind the alternator was bad, and after replacment there is no charging.
The only thing I dont know is that the connector to the alternator that have four slots on them should all be power or 3 power and 1 ground. When I checked the plug with the light test the 2 lit-up bright, one very dim and the 4th none.
any help would be appreciated. thanks in advance guys...
problem fixed...
I had a fuse replaced at a shop and they did not connect the wire in the back of the fuse. It took me over a month to pin point the problem. next time dont just check the fuse, check the wires that lead to the fuse, specially if u let another person work on ## car.
lessen learned, dont trust anyone with your car.
thanks for the space.
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
