1G Charging issues.
turbo4awd
206
Dec 19, 2008
Carlisle, Pennsylvania
While changing the 02 sensor i bumped the alternator causing a small spark. After that the battery is only showing 11.1 i changed the alternator same issue checked all fuses none are blown. Also change alt relay. If i hit the pop up lights they dont work unless car is started. Windows door locks dome lights blower motor etc dont work unless car is started. No accessorys unless car is running
