Onefast97GST
- 0
- Aug 10, 2004
Central WI,
Wisconsin
99GSX
The transfer case takes 1.1 pints. The manual illistrates that 1.1 pints will be level with the bottom part of the fill plug. I completely drained any oil that i could. I even raised the front of the vehichle so the oil would drain towards the back which is where the drain plug is on the transfer case.
1.1 pints is just a little bit less than the size of a 20oz pop. So i put my Redline oil in the pop bottle and put it in the transfer case. However, you simply cannot add 1.1 pints. It wants to gush out of the oil plug.
So is there a certain amount of oil that won't come out of the transfer case unless you take it out of the car, drain it end on end, take it apart, etc..?? I put the whole 1.1 pints in and shoved the plug in quick. A little bit more can't hurt, can it.
If anyone can answer my 2 questions, I would appreciate so i can get that dam thing off the jackstands tonight.
Thanks!!!!
Thanks!!!!
