changin front left axle
qbanit0gsx
95
Feb 12, 2004
west palm beach, Florida
i am replacin the front left cv axle i was wonderin if the left cv axle is longer than the right cv axle. When i pulled out the cv axle it seperated into two seperate pieces. if im replacin it do i only replace the part that goes to the tire or do i replace both parts including the extension the goes to the trannie. Or is it supposed to be one whole piece.
any ideas please :dsm:
Hi,
The driver side axle assembly is two different pieces. One is "connected" so to speak to the tranny and a carrier bearing and the other from the carrier bearing to the wheel hub. I dont think you need to replace them both when you are replacing the axle, I see no reason to.
Bill
They're different lengths.
There are two pieces. Replace the "part that goes into the tire", and re-use the "extension to the tranny".
