Changed heater core, now no blinkers.
v8s_are_slow
2,824
280
Sep 30, 2002
Panama City, Florida
Changed my heater core and now I have no blinkers. The hazards work. Not sure if there was a connector I missed under the dash or what. Anyone know of where all I need to look for a connector, or fuse, or relay? Not sure how many connectors could be the culprit, don't have a wiring diagram, and don't care to pull my dash just to try and figure it out. Thanks.
Retrace everything? I pulled the entire dash. Kinda hard to just retrace everything. Lol. But thanks for the support.
Well, I'm kinda figuring that too. But would rather know where any and all connections are to make it a little easier to track down. Cause I don't care to pull the dash again anytime soon. Pulling the dash, ftl.
So anyway, I thought I just didn't have blinkers. But apparently I don't have blinkers, flashers (I dunno why I thought I did), no brake lights, and the blower for my heater only works on high. Or it's off. No inbetween.
So far I've only found one connection that I can't find the other end to, or where it plugs in. It's behind the radio. Anyone have any idea where this would go, or if there's anything else that might be the cause??? My headlights and tail lights work at least.
Okay, I'm still having no luck with this thing. I've been searching around though. I had pulled the relay in the fuse panel on the driver's side and put it back in. I checked to make sure I put it back in the right way but there was only one direction to put it in. I saw others mention the hazard lights switch. How would I test to see if it's bad or not? Anyone know?
Anyone have any other ideas of things to look at, assuming I connected everything back properly??? I really need to figure this out fast being that it's my DD. Thanks.
If im correct look around for a box that should plug into it. I pulled my dash recently, i belive that box controls the blinkers.
Might be true on a 1g. But I can't seem to find anything. About to go look some more. Yay. Cold and windy outside too :(
Here it is hope it solve your problem. :)
I love you guys/this forum :) I so needed something right to happen today. Lol.
