2G Changed Crank Pulley and belts, now it won't start
pedroDurant619
Mar 12, 2015
San Diego, California
So last night I changed my crank pulley. Also replaced alternator belt and AC belt. I turned on the car and heard grinding noise coming from the pulley side. Was on for 20 seconds and the car shut off by its self. I tried to turn back on and it turns over normally but car does not start any ideas. Very much appreciated.
The cam sprocket marks must not only align with each other but also with the head surface. When all sprockets are on their marks, it helps to place a straight edge horizontally across the center of the cam shaft sprocket attaching bolts. Then you can just align the cam sprocket marks with the ruler (note dowel pins must be up).
