changed all front seals...still leaking oil
Where is the oil leaking from??? from the timing belt side, front, rear, or by the transmission side??? How many miles dose your car have too as well? If your car is leaking oil from and inbetween the transmission and engine most likely its the rear main seal.
well i do think its the cam seals. the oil travels down through the engine and makes it look likeits coming from somewhere else. but this is the second time i change them. am i supposed to apply rtv or do anything diffrent?
Personally, I like to rub some kind of lubricant/sealant around any gasket/seal that i put on a car just to ensure a tight fit. You might hae to wind up takin it back off an putting something on it. You might also have a wrinkle in the seal or something dumb. Just be very careful if you decide to pull it back off to make sure its seated right the next time around. Good luck and keep us posted.
  • Wanted 2g WTB CLEAN HVAC PARTS
    Good condition , clean please no rodent infestation
    • ames905
  • Wanted 1g WTB: 4 Bolt Axle Cups.
    Looking for a set if 4 bolt axle cups for a 1g. Located in Canada.
    • blaster1812
  • For sale 2g 2G Manual Shifter Cables ( including NEW bronze bushings )
    2G Manual Shifter Cables $90 + shipping & paypal fees* I will be including NEW bronze bushings...
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
