Chaging my timing with CAS
it is clockwise to advance, but I would only do that if you are too far retarded. what is ur timing at 1000 rpm? i believe it should be around 10 degrees. if you want more advance, then work on gettin rid of knock and all that crap that affects timing
base timing should be at 5. If you are highly modded and cannot reduce knock, try retarding the timing to 3-4. To check base timing, you must ground the ECU and use a timing light.
