Center housing bolt - SBR G50
Omega
1,558
10
Oct 10, 2002
Randolph, New Jersey
Upon a routine inspection of the engine the other day, I found that the top bolt was just hangin' out. The bracket has also popped out of the lower bolt too.
What's the deal? Is this something I should look for from now on? The other bolts look fine, but I am a little irked that this happend.
Are you talking about where the center cartridge bolts to the turbine housing? If so this is a common on PTE's. Apparently they have upgraded bolts for this.
Yup, center housing to the exhaust housing.
New bolts huh? What's the deal with SBR.. why is the site down? Does anyone have their number so I can call and they can send me said bolts?
You can buy the bolts at any hardware store. Just take one with you to get the right size. If your turbo is a PTE version then you might be able to contact them for bolts. I just went to the local hardware store and purchased stainless bolts.
