Cat-back Exhaust System
Status
Not open for further replies.
make your own. get a O2 housing, 3in DP, test pipe and then cut off the muffler and weld on a strait pipe with a exhaust tip. sound so so good. deep and throaty
Are you sure the OP has access to a welder, tubing bender, plasma cutter/cut-off wheel - or a tech with all the above supplies?
Are you serious????
Well the best cheap exhausts are off of ebay. They don't sound to bad and they are not priced bad at all.
^ True that, and at the very least if the pipes are mandrel bent (which they should be) you could always swap out muffler if you don't like the one it comes with.
scorpio87m1 said:
Anyone know where i can get a good turbo cat-back exhaust system for a 95 gst
Naw, I don't think anyone sells exhaust systems for your whip. :rolleyes: SEARCH. Search through the forums and through all of our vendors. Please work your virtual legs before starting such a ridiculous thread.
I'm gonna say yes, then read my most previous post :thumb:
ROFL
I think I'm gonna like these forums.
ebay buddy!....if you look hard enough you can find a good name brand exhaust...make sure you get a cat-delete pipe too since you dont need to worry about emissions
Status
