awd4g63
- 1,335
- 2
- Oct 22, 2002
Savannah,
Georgia
My car's been running very poorly after my rebuild. I seem to think it's my ignition timing. The car has no power at all (so slow that it's almost dangerous to drive in traffic), idles choppy, and just all in all won't drive right. After getting everything back together with new plugs, wires, new CAS, new coil pack, new bottom end and top end (2g/1g pistons/rods... complete stock head), and basically everything you would replace during a rebuild. Timing belt was done right, and I did a compression test just to be sure... gauge was right around 180 on all 4 cylinders. I went to try and set the ignition timing by grounding both the OBD1 plug and the plug on the firewall and using a timing light. I got everything hooked up right, timing light was working great and all and went to adjust the CAS, but could even get the mark on my harmonic balancer to line up at all with the Timing/TDC marks on the timing cover. If I retarded the CAS all the way, it would get within an inch or so of hitting the marks, and with the CAS advanced around halfway or more, the car hardly ran at all. I pulled the CAS to see if it was in the wrong way (brought the #1 cylinder to TDC and lined the marks up on the CAS) and reinserted it. It was right to begin with, but for the hell of it, I flipped the tabs 180 degrees and put it back in and the car ran exactly the same as it did. So, I thought the CAS was bad, so I swapped out a known good one off of a friend's car and put it on mine. It ran the exact same way on my car with the same TDC mark results. The one I had on my car ran fine on his car.
If anyone has any help they can offer, please do... I'm tired of messing with this thing and I'm running out of motivation and ideas...
Thanks,
Jon
Thanks,
Jon
