CAS help
mattspyder
1,046
Nov 2, 2004
del taco, Wisconsin
I'm putting a 1g grey top CAS in my 98 eclipse gsx 7 bolt. problem is part of the harness is cut by the far right injector, I've got a triangle plug wired into the cas and three wires that wire up into the old 2g cas plug. problem is I don't know where to plug the triangle plug into.
I've got 2 plugs(pic 1) coming from the back of the 7 bolt block, do I need those?
You need to build a 1G in 97-99 harness.
Check out -> RRE Instructions
The triangle crank plug, is most likely on the back of the block near the lower timing cover, but not 100% sure about that.
(There are only Green Top[Optical] and Black Top[Hall Effect], 1G CAS, no Grey Tops.)
Only 1 wire goes to the stock cas from the new 1g cas. Follow the instructions that ceddy provided.
