Carpet replacement [Merged 10-7]
I thought I'd post here again about dying my carpet black. I was planning on doing it and finally started. It's sitting in the dye right now, so it should be done in a couple days. I'll let you guys know if it comes out good, because it was pretty cheap and easy.
I have a 99 Eclipse GST and looking to replace the gray carpet since it's starting to get beat up. Where can I get the best interior carpet that's the closest if not OEM especially with the extra sound deading padding? Thanks in advanced!:dsm:
I want to redo my carpeting myself because I want to carpet where the back seats are and remove the back seats. I also plan on doing a battery relocation at some point. I saw Defiant's post about oven heated sand bags, one what is that and two does anyone have a site I can just buy the carpeting not cut or molded. Also what would you suggest as far as making a frame for the carpeting, or can I just carpet over what is under the back seats?
Okay well i have been searching for awhile now to order some new black carpet for a 2g. i wanted to switch over to black carpeting and i have herd a lot of people ordering carpet and it doesnt fit at all. so i just wanted to see if anyone has ordered carpet for thier DSM on the internet and they like it. here is what i had in mind:
its the 4th one down. the complete set. but then it says FWD, does that matter?
Eclipse Carpet--Molded Eclipse Carpet--Mitsubishi Eclipse Carpet
Of course you can't get OEM carpet anymore but I assume you mean OEM-style.
It will never fit as perfect as OEM but as long as the carpet is made by ACC it is about the best you will find for aftermarket carpet and it works quite well.
is ti molded tho? like almost perfectly molded?
Well I would say on a scale of 0-10 with 10 being a perfect mold, I would say it was a 7 at most. The problem is that it is shipped folded up in a box, and when you pull it out, you pretty much have to form it yourself, save for the area directly beneath the front seats. That was ok.
I was able to get a tan one from the dealer for a 2gb Talon I flipped about 6 months ago. Took them a week to find one on the top shelf of some store room a few states over. I don't remember it being over $200 either, so it's worth at least asking.
