Car wont stay on
dsm91TalonTSi
62
May 29, 2006
Burgettstown, Pennsylvania
Well, i goto start it, and it turns over, and revs for about 2100rpm and then dies. if i gas it, it'll still die. log files attached
Suggestion copied from same thread on ECMLink forums:
The fuel pump relay in the 1G has two different coils. One activates the relay (turning on the fuel pump) when the key is in the Start position, the other is controlled by the ECU. I would suspect that the coil controlled by the ECU isn't being activated either because of a bad relay, a bad driver in the ECU, or bad wiring in between.
Dave
