TalonJohn94
- 592
- 11
- Jan 30, 2003
Katy,
Texas
I'll cut to the chase.
I installed a new cylinder head, (new springs and valves - factory cams) including obviously a timing belt job.
After learning I had a bad coil pack I replaced it. But still now the car only starts if you floor the gas. Then it won't hold idle and you can tell it is running rough. Tested spark on all 4 cylinders and I have spark. I know I have fuel to the injectors because the new spark plugs are now dark and smell like fuel.
Which brings me to my question. I did a compression test and they're pretty even across the board at around 65 - 70. Obviously that's low. So how can I determine whether the low compression is due to the cylinder walls having been washed by fuel OR if its valve timing?
.... that way I can log the ECU to see if the IAT and ECT sensors are making equal readings.
