car wont start
Raydsm
May 17, 2009
Suffolk, Virginia
okay i have a 94 gs 2.0 non turbo it was running great til i rip everything apart to put into another car but decide to go turbo with that one so i put my car fully back together and went to start it does not fire up i check everything and i got no fuel getting to my engine fuel gauge read empty but put 20 buck in and still reads empty i check the test wire on the fire wall and it didnt light up and check my wiring everything is wire up right just not getting fuel to my engine
Check the main fuse panel under the hood. Make sure you are getting power. If not check your ground wires.
okay i check the ground and fuses i got power to the fuse panel and i found one ground wire broke and fix tht still no nothing. and thanks bud92gsx for tht i goin to see what tht will do for me i keep yall updated
check for power at fuel pump.....should have 12 volts....if your have 12 volts...perform voltage drop test across fuel pump to see if pump is using the whole 12 volts...if so...suspect faulty fuel pump...if not....suspect ground or bad connections...
okay i did a jumper to the fuel pump and after i did that everything start workin and still is i dont know what cause this but i dont see the end of this problem yet. but now it all workin
