1G Car won't start!
Theron
Aug 31, 2010
Spencer, Iowa
I have a 1990 Eagle Talon Tsi AWD Turbo. Recently I have replaced the exhaust manifold, rediator, water pump, and timing belt. All done professionaly. The car started long enough for me to get if home. The next morning I couldn't get it to start. I tryed for a good hour, and still no luck. The fuel pump works, new injectors and fuel rail, as well as the filter being clean and healthy. My coil is good, and I'm getting sparks to all plugs gapped at 0.022. The ECU is as well good. Any help would be much appreiciated. Thank you.
Timing is correct. Where is the MPI fuse located? Pic would help alot. Everything on the belt side is alligned along with the firing order reset. Still no luck. It will crank, but no start.
