Car won't start please help..
90Tsi AWD
77
Jan 5, 2006
Long Beach, California
I just got through changing my oil, spark plugs (ngk's), and battery wire terminals and now my car won't evn crank. I turn the key and nothing happens, I wiggles the positive wire a bit and it got current but as soon as I tried to start it it would go dead again. Now if I try to move the wires nothing happens. what should I look for to fix this problem.
Make sure your postive and negative battery cables are making a good connection, get a voltmeter and make sure you got 12.5 volts.
I tried moving the cables and nothing happens, is there some sore of alarm system from the factory that could be causing it not to start?
just redo the battery connections and spark plugs. you had to off done something wrong or forgot to do something when changing everything
go over all the connections an make sure they are tight and if neccesary take a wire brush to the battery terminals to ensure a good conncection.
I tried giving it a jump and when the key is in the ON position the radio and lights work but as soon as I try to crank it everything shuts down again
Make sure that the connection in the battery doesnt have a rust or something(dirt) clean it brush or I use sand paper in mine :)
Did you use a battery terminal cleaner at all? I had a friend that used the brush a little too much and he brushed soo much metal off that his positive terminal wouldn't make a connection anymore and the nut was the tightest it can go.
thanks guys, it ended up being the brand new terminals i bought. the paint on them wouldn't let any current go through them so I just sanded all the paint off and problem solved.once again thanks alot
LOL...the same thing happened to me...only i noticed it BEFORE i put it on...
:tease:
you would think those companies would put a little more effort into their products.
