car wont go into gear.
Nikolay_Ruskov
231
3
Jan 25, 2008
san antonio, Texas
Ok.When my car is off I can get in to gear,but when is on i cant .
I try to adjust the rod,but still nothing..
Is there a problem if my fork is lot more in the right side?
You should have a friend look at the slave while you push the clutch to see if its working right, if not replace it.
I had same problem with mine, end up being bad slave cylinder, pull the rubber boot of it to see if there any fluid in it.
Sent from my iPhone using Tapatalk while taking a shit
Did you just recently did a clutch job?
Could be a numerous things, from bad slave, to pressure plate, worn clutch or bad flywheel step.
I had the same problem. I took off my whole tranny and redid it twice. Never really figure what it specifically was. The only thing i did different was install the clutch back in without bleeding it, which fixed my problem.
One thing it could be is a spring from your clutch pack popped out and is not allowing your clutch to do its job. I have seen this numerous times in the shop. And you cant tell until you remove the transmission and visually look. It wont make any kind of sounds to make you think something is loose because it is turning jammed with everything else.
I know what it is ..But i was hopping to find different solution ,because i just put the transmission back on.I shim the pivot ball when i was using the ACT TOB and before 4 days i open the transmission to put the stock TOB, because the ACT TOB sucks and i did't remove the washer under the pivot ball. that's why i got this problem now.
my car does this in 3rd gear but mines goin in when off and when on it acts like its in neutral. and makes some sounds while in but not grinding
