Car won"t even start with spark and fuel!?!?!?!?!?
92_talon584
Sep 5, 2007
Cherokee, Iowa
like the title say's the car wont even try to start nothing at all has spark in all 4 made sure to check them. It is getting fuel so much the plugs are wet like soaked. tomorrow i plan on testing the coolent temp sensor ,CAS,replace plugs,boost leak test,and possibly compression test ( if i can get ahold of one ), and check my timing. i have tried 4 different ecu's and nothing im just at my wit's end with this thing and a really want to drive it again. Thanks guys.
is the car even cranking??? If it cranks then disregard my post but if it's not even cranking check your starter and your ign switch
May I ask why it was not running in the first place. Did you do some type of repair then it wouldnt start? I would start by geting new plugs, I have had it a few times ware it would not start because of fouled plugs. Check the CAS, Check MAF, Check compression. Then i would make sure its perfectly in time. If you do that you will find your problem.
well turns out 0 psi across the board im 98.12% sure it jumped timing sense i can't turn the car over without useing the key by hand it is impossible..
Yeah it def. sounds like your timing belt jumped. There is only one way to be sure. Time to get dirty ,so pull your lower timing cover and check out where your timing marks are at. I hate to say it bro. If you have 0 psi across the board that most likely means bent valves.
yea its ok i havn't done any head work on this one yet so ill just be doing it earlier than id thought.. it just sucks because i just did a manual swap and it was running when i parked it go to start it and she just turns over and over and over WTF!! then to find this out damn! but i guess ill just have to hope its only bent valves.. anybody know were you can get good prices on arps n head gaskets, along with an oem timing kit??
Try extreme psi, oem gasket and everything, stm has kits also, about your best bet. Go ahead and spend the money all in the right place. Do it all, call it done. ARP'S look at the vendors many will price match.
  • For sale 2g Early 95 2GA DSM Hardtop for sale (5-speed)
    2G DSM for sale
    • codexes21
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
