Car stall when shifting on gear and press the gas
michaelskie1
Feb 21, 2008
hayward, California
Need help??
I have a gst 98 and i have a problem when i shift it to gear then press the gas the car stall/die and start it again it was good on the idle but i notice that the rpm is unstable. No check engine , ill check the iac resistance is good all are 28-30 ohm , i check the alternator. And one more thing i notice that my oil filler smells like mix gasoline.
i have HKS recirculated BOV i have couple of leaks, I just fixed it. One more thing i heard some air out from my oil cap is that natural?. but all possible leaks are fix using teflon, zip ties, hose clamp and rtv gasket maker..
